Stock Fog Lights wiring?
Calling all radio gurus
pulling with met. brake pads?
My truck does not have any stock fogs, so I'm putting on a set. I see that the wiring is already there but I have one question. I know that they are activated throught the HL switch, but Do they work with only the parking lights on as well as with low beams? The 20 gauge wire seems small? Thanks in advance,
Yes they do work with just the parking lights on but you are missing the relays. You will need two of them and they are around $6 ea. if my memory serves me correct. They just snap in to the fuse panel under the hood on the drivers side. Grap a manaul (sp) for correct placement or maybe someone here has a photo...
You will like the difference.
