Archived stock#for brake line
Archived Torque Converter Lockup Problem Following GSK Install
Archived Drivetrain question '05 2500 CTD w/ manual 4wd selector & 48re
droped wrench across bat post an brake line this line is between mastercil. and antilok controler. truck is 01 4x4 6speed all the pictures in shop man. are a cartoons can find no stock # help.
You can buy different lengths of brake line at most reputable auto parts places, only problem is the fittings on the new line are probably not going to be right. Get a piece of new line that is a little longer than you need, find a place that can double flare steel tubing and have them cut one end off and reuse your fittings. bg
Yeah just go to Napa, Carquest, Shucks, etc and get a length of brakeline.
sgdufresne said:
I dropped a wrench across the battery posts and a brake line. This line is in between the master cylinder and the antilock controller.
The truck is 01 4x4 6 speed.
All of the the pictures in shop manual are cartoons and I can't find a stock #
Help!
