I'm looking to gather some data from Gen III owners whose trucks are stock that also have boost/EGT guages. Airflow/exhaust mods are OK but no fueling mods, boxes, etc. If you have a performance box that can be set to stock, don't just set it there and take numbers... I'd prefer that you drove at least 200 miles at that setting first.
What I'm looking for is...
EGT at idle
EGT/boost @ 50mph, level ground
EGT/boost @ 65mph, level ground
Max EGT/boost through the gears during a WOT pull from a dig
Please specify whether 2WD, 4WD, DRW, rear diff ratio, and whether you have non factory tires (ie taller), auto or manual, and approx air temp
Dyno numbers would be helpful if you ever did a pull.
If you're just going from memory of the way your truck was set up in the past, please state so.
EGT at idle
