for those that care here's the scoop on impedance and resistance.
All speakers have impedance that varies by frequency. Resistance as most everyone knows is the nature of an object to resist current flow. IMPEDANCE however, is a bit different, it is dependent on reactance and frequency... in fact impedance generally only occurs in AC circuits, I say generally because fluctuating DC circuits also have it, (AC circuits with DC bias).
A coil increases resistance as the frequency gets higher, where a capacitor is opposite and increases resitance as the frequency gets lower. This reactance is neccessary for crossovers to function. Crossover's work by combining the both coils and capactors to block frequencies from going to tweeters or woofers depending on the respective frequency.
OK, so the big speaker issue with "resistance". Manufacterers rate these speakers at an OHM value, and is achieved by placing a DC current across the voice coil, this inturn gives a "resistance" of 4, 6, 8 ohms etc... This coil almost never operates at that impedance... I say impedance because when an ac signal is applied "resistance" becomes impedance. When it is, it's called at resonance... a whole othe rball of yarn to talk about. The voice coils impedance is constantly fluctuating because the frequency constantly changes. The dc resistance of a 4 ohm speaker will vary depending on a ton of things, but generally it's somewhat close. 3. 2 vice 4 Ohms or something like that, heat, and circuit content, heck uncalibrated equipment can cause variances. 4 ohms is not a lot of resistance.
Anyway fellas there you have my lesson. 4 ohm's are common in vehicles, 8 in homes, although 6 is gaining popularity.
