PGiannetto said:
Thatks for replies. the reason I started a new thread is because 95% of trucks with " death wobble" have been lifted trucks with different size tires. Then most of the solutions have been "stay with stock" & " you need load range E tires". My point is I have a stock truck & stock tires. Anybody else having this problem with completey stock trucks? If so what cured it? thanks!
Valid point...
Thing is, lifting a truck doesn't allways change the geometry a ton, but it might... I do see what you mean though...
I do want to add that a 3 inch taller D rated tire isn't much different than a heavy E rated smaller tire... ... . If it's out of round/ballance, it needs to be fixed...
I'm gonna' copy paste myself some out of the other thread as I does apply to you... My opinion in your case.....
#1, your tires are too far out of ballance or are defective... .
#2, Dodge screwed up and used rubber bushings in the trackbar...
Just my opinions...
Don Thuren... .
________________________________
_______________________________________
"Let me post some things here as I've dealt with TONS of death wobble issues on various vehicles, but for this discussion, I'll focus on the Dodge front end...
Three things that you have to get before understanding where I'm coming from...
#1, the tires are USUALLY what get the death wobble going. It can be for various reasons but the tires ARE out of ballance/round if you get death wobble when you DON'T hit a bump to get it going. This may be a very small amount as there is no such thing as a perfectly ballanced tire but regardless, the tires are the MAIN thing to focus on. I've seen D rated and E rated tires create DW so, IMO, the tire "rating" doesn't really have to do with creating DW... A ballanced tire is a ballanced tire...
#2, If you get DW from hitting a large bump, it's most likely the shocks... I'da never thought this until recently when a customer got DW after installing leveling coils and nothing else. . He also had previously installed my trackbar... As we were chasing the DW, and I was building him some Fox shocks, he decided to go to 4wheel parts to get it checked out. . They said DUAL-STABILIZERS would fix it FOR-SURE!!! eeeeeeeeeehhhhhhhhh, NOT!!!!!!!!! Anyway... . DW was the exact same. He also had the stock size E rated tire. So, he dealt with the DW hoping new tires would solve it, but before he had the tires on I finished his shocks. The shocks COMPLETELY fixed the DW. . I would have NEVER thought but it was so... The conclusion I came to is that this type of DW is created by the control arms moving "front-to-back" once a lift is put on. The bad shocks are getting the vibation to transmit into the steering...
#3. Now , and most important, the track bar is the one thing that can bring all of these factors to a minimum. If you have ANY noticable movement in the track bar it needs to be fixed along with getting the tires ballanced(speed related DW). If there is movement in the trackbar it DIRECTLY feeds back into the steering wheel in a HUGE amount. When DW is happening you can hold you steering wheel perfectly center, as most of the wobble is being forced out of the trackbar, and watch your tires go NUTS... This would be the reason the trackbar is so prone to being the main factor... They are MUCH more touchy than you think as . 25" of trackbar play is 5 degrees of tire angle, or, almost a 1/4 turn of the wheel... .
Don Thuren"
