Hey guys,
Thought I would share my experiences with the DW. Have had many trucks come through the shop with the problem. First I have to start by agreeing with Greg and Don, there is no one fix. I have changed out tires on a truck and solved the problem. I have replaced worn out wheel bearings and solved the problem. I have also added dual stabilizers and solved the problem. My take on the reason behind this is front end steering "y" design combined with the short control arms. As the axle goes through it's cycle it moves down and to the left extending, and up to the right compressing, meanwhile the toe is changing in a rapid fashion at the same time. This creates alot of movement at one time. If there is any loose components in the steering, blown shocks, soft side wall tire, or worn track bar it will allow the axle to move at will with little resistance. If the pivot points on the control arms were moved further back, then the movements of the axle wouldnt be so sudden. Take the new Ford F250 for example. They are a three link system with long raius arms that are almost parallel to the ground. The only death wobble I have ever seen on one of those was when a shop had done a lift and left the pan rod loose at the frame end. DW is annoying and sometimes just scary, but can be cured. Everything that connects to the axle must be tight and good working condition along with the proper tires and alignment.
