Engine/Transmission (1994 - 1998) stock turbo modification
2nd Gen Non-Engine/Transmission Trailer Wiring
Engine/Transmission (1998.5 - 2002) Broken Pump Wire
There seems to be allot of knowledgeable members on this site. Here's a question for you. Can You get more LOW end boost pressure out of the turbo? Is there any adjustment anywhere?
Rite now the wast-gate is set to factory specs and opens at 23lbs boost when the rpm's are up there. I Have installed larger injectors , slid the plate forward a little, and would like to get some more air with the fuel on the low end. Not sure if it's possible with the stock turbo. thanks
