Storing Injectors
Rusty Bolts Pyro install
automatic transmission questions
I have a couple sets of used injectors and I would like to know a good way to store them, until I want to use them again. Should I just wrap them up in an oiled rag? Any ideas welcome.
Thanks, Jim
The only concern I'd have storing injectors is that they don't get banged around. Wrapping them individually in a rag sounds good, probably doesn't even need to be oily.
Jim, when you pull them don't wipe them off or anything, just put them in a plastic sandwich bag all covered with oil and dripping diesel fuel. You can then put them in a box and put that somewhere they will not get bumped or bruised. Rust and dinged tips are the only real problems you need to avoid.
If they are already out just take a handfull of oil and coat them before putting them in the bags.
