Changed the fuel filter yesterday for the first time at 16,000km - really easy job and no spillage if you pull the cap/filter up slowly and carefully. The old filter was quite black with what I assume is algae, it didn't look like particulate and there was zero sediment in the canister as well.
Restarting was a battle. I cycled the lift pump 3 times by bumping the starter. On the 4th cycle the LP tone changed and I assumed the canister had filled up so I tried starting it. It ran for a few revolutions and then died. It took another 5 or 6 cycles of LP priming and several cranking sessions before it finally started.
I had the LP replaced and it makes 15/10psi at idle so I think it's OK. The truck was pointed uphill slightly so maybe some fuel drained back from the VP44 to the filter canister causing a worse than normal loss of prime.
Anyways for you other diesel beginners, like I said an easy procedure overall so don't put it off if you're nervous and certainly don't pay someone to do it. Get a 1-1/8 box end wrench or socket so you don't break the plastic cap, and a chunk of old garden hose to stick over the useless factory drain tube.
Rich
Rich
