I thought about putting a stack on my truck. I wanted to put it beside the bed right in the groove between the cab and the bed on the passenger side. However, for fear of a divorce or something like that I didn't do that. I was going to customize a set of running boards to go around the base of the pipe. I was also going to put a heat shield on it. Case-IH sell some nice pipes and heat shields for the Magnum tractors (Cummins powered of course). If I remeber correctly, I could get a 4" curved stack with a heat shield for under $200 (seemed to be fairly good quality too). I think the pipe would have been even with the top of the cab. Currently I am happy with the rear exhaust setup I have because it can be loud or it can be quiet in the cab. I will try to get some pictures of the exhaust setup on my website in the next couple of weeks.
Jeremy Sweeten 1992 Dodge W-250 4x4 Cummins Diesel, Intercooled,LE Package, 166K, AT, Warner Hubs, Dana 60HD 4,060 lb. front axle and Dana 70 6,084 lb. limited slip rear axle with 3. 54 gears, NPG 205 transfer case, 3. 5" Banks exhaust with straight pipe and 4" tip, K&N air filter. Tekonsha Voyager XP electric brake controller.
http://home.earthlink.net/~sweeten1/index.htm
