AH64ID you are the man. i swapped and it is back to 14.5 volts on both, and the dash as well. i still not clear how it works ,but it does. thank you all.k
Cooked Primary Field Control circuit in your ECM from factory ground issue. Do an external voltage regulator, put a load ballast in the hot wire from ECM to at least not have a dead dash needle(not accurate just making ECM think it’s doing something) and bypass battery sensor under driver’s side battery bucket. Or a repaired ECM or new. As I recall Mopar1974 on his site listed a fix for that bad ECM charging circuit ground.
ECM reads off driver’s side battery. Alternator charges on passengers side battery.
