I wrecked my Dodge 2005 2500 w/ diesel and until recently was going to part it out. Now it looks like I'll fix it. Right now I cannot get the elec fuel pump working. I have it set up with a pressure switch (from Richard at Glacier) which turns off pump when system is pressurized. At that point the mechanical pump takes over and the elec pump is only used until fuel system reaches whatever pressure it's set at. It was working well for years, but I cannot seem to get it running now.
My question is why/what would repeatedly turn power off to my elec pump after a few seconds after I turn key to on? I can hear a 'click' when power to circuit is turned off. It acts like a circuit breaker going off each time. In addition, the elec. pump never turns on.
I have to either get the elec pump going again or the mechanical one if I hope to start this. I cannot get fuel to engine w/ mech. pump, I guess because there is so much fuel line, 2 filters, and a very long run for both. Fuel comes from tank to a small strainer, then goes to mech. pump attached to balancer, then it goes through 2 fillers and then turns around and goes to the stock filtration canister attached to intake manifold. I did call Glacier Diesel (who sold me this 10+ years ago) and it turns out the owner, Richard, has sold it to new people. The guy I talked to nevertheless got all my information and will talk to Richard about this. It says in install manual that the mech. pump has grease in it to enable it to 'pull' vacuum the first time (of course the elec pump is there to, so it's probably not needed w/ elec pump). Although I've filled the 2 filter canisters with diesel I can't get it to start. I've even hooked up a motor that turned over the mechanical pump but it won't draw, or draw enough to 'pull' fuel.
I hesitate to also fill the stock fuel filter canister, I've been told it's too dangerous to bypass this last, probably most important filter, in order to protect the injectors from debris. Possibly I will have to do this, would this be enough to keep engine running until mech. pump fills it's system?
