For whatever reason, especially for the first several minutes, when I start the 2006 truck is has the strangest exhaust smell, really hard to take when your in the area of the exhaust. Could it be a converter?
Also, just recently I've lost power, and have a rough idle. I took it to the dealership, the said the would need to replace the lift pump (at my expense since they found dirt in the filter housing) and do additional testing to see if it's an injector problem. Do you thing they're just trying to give me the run around? I pulled the filter, cleaned the housing and bumped the starter without the filter in place. The filter housing filled up really quick... ... . doesn't seem like a lift pump problem to me.
Oh, the truck has 89K miles and is stock... ... . I had one of the cheapass diesel modules on it for a while but removed it several thousand miles before this problem.
Sorry for the novel... ... any help is appreciated!!
I sure miss the 12 valve days!
