In the last 2-3 months I have had this problem happen 4 times.
I was leaving a parking lot after having lunch , outside temp was about 80. I go to give it some throttle and it bogged. I then lifted and throttled it again and it was fine. It has done this twice in similar situations. It reminded me of when a carbed motor loses an accelerator pump.
Lastly I just returned from a 1000 mile trip , we had driven about 4 hours and took a short break. Truck sat about 15 minutes. Got back in started it and got back on the highway. Well while cruising the truck seemed to have lost power, and throttle response. I gave it more throttle and it came back to life. It did this twice in about 10 miles and then was fine the rest of the trip.
Today I will check the fuel pressure because my first thought is a problem with the FASS. I recently had high flow injector tubes installed and have noticed a rougher idle (sometimes) . I will also see if I have any codes.
I really hope it isn't the FASS , I purchased this to eliminate worrying about that damn lift pump. The truck just turned 60,000 miles
I understand that without fuel pressure numbers and or codes it is pretty hard to diagnose ,but just wanted to know if it has happened to anyone else.
