My truck has always started fine untill about a month ago with absolutely no warning. It has no pattern to it, it just does it whenever, unless I kill it and start it back up within a few minutes. Sometimes it will start fine cold but then other times it won't. When it does it the engine will cranck for 5-7 seconds and then fire (but not start) and then it goes back to cranking and then start soon after that, all in one turn of the key. I draned the fuel filter canister and cleaned it out. That didn't fix it. When it started I had the set of DD3 Jammers in the truck, I thought that might be it. But when I switched to the JR Stage 4's, nothing changed. Fuel pressure is perfect. Right at 20psi. The truck runs great, no hesitation, no white smoke, no nothing. I plugged the Snap On Scanner into it to try to maybe get a code out of it to see what was going on and the scanner didn't say anything. The only thing I can think of is a leak somewhere in the lines. But it doesn't leak anywhere. I'm stumped. Please help! Thanks.
Eric
Eric
