I started smelling coolant and found the right side weeping. Coolant tested to be good to -48 degrees. The local diesel shop said they've only seen this twice before. The crack is 2. 5 inches long and 3 inches below the soft plugs,in the middle of the block,and runs horizontally under the step of the block.
It's in a '97 3500, 5 Spd. , 152,000 miles. 3:55 gears, Gear Vendor overdrive, BD Exhaust Brake, 325 Hp. , 4" exhaust, 255/85 R 16 tires, Transfer Flow tank.
Is this a common Cummins issue? Is there a Repair for this or will I be sending my block to the local scap yard?
