Dumb, Dumb, Dumb. #@$%!
Last year I installed a DSS steering stabilizer and a front end hitch. No big problems. Well tonight I was under the truck and it looked like one of the stabilizer bar clamp bolts was loose (these bolts also hold the DSS and hitch). Well without referring to the torque value book, I proceeded to tighten the bolt…… yep I stripped it. I have not removed it yet to see if it’s the bolt or the nut…. But most likely the nut.
Question: What the best way to fix this problem. Virtually no access to the frame welded nut. I’d like to find a fix that only requires removing the bolt…. . I’d rather not remove the whole DSS and hitch.
Would an over length bolt threaded thru the stripped nut and threaded into a nut that is somehow fished into the area be feasible. I think I could get the nut started…. But not sure about keeping it from spinning while tightening the bolt.
I guess a fix that involves removing the DSS and hitch would use a helicoil type process. I’ve never done one, but I guess I could learn.
Any ideas would be appreciated. Thanks
