Stubling on accel & high temp #6 injector
Help identifying "chirp" sound when putting my 48re in gear
Brake and ABS light on all the time
Hey Freebore, thats a great idea for the insulation! I was going to try to buy a replacement or sew somw webbing into the current stuff, but I like the glue it idea much better.
Filters and oil test kit arrived. I located a better clicker for this torqe range. As soon as I get past this block of work days I can get back to it. I want to repeat my tests and run a few more before I buy any injector(s).
Thanks Guys
Jim
I put a new fuel filter in late Sat night, filled w/ Sea Foam, ran about 1 min. Let sit until sunday night. Drove truck about 10miles, still has stumble, more noticable once it was @ op temp. Maybe not quite as bad, hard to tell. When I rev it in idle it runs rough from about 1400-1600 & then smooths out some. Still seems down a bit on power. But now the manifold temps are: 242, 237, 241, 243, 251, 256/248 (diff when moving the IR gun 1/2"). So I am somewhat releaved that the high temp is gone, at least for now, but it is still not running well enough to drive. Next up is an oil test kit, oil change (just incase there is fuel in the oil). Found out my low cost scanner can not do contrib test etc on the 5.9. May have to find a shop w/ a scan computer or maybe try to buy one if not too expensive. More to come.
Thanks!!!!
Jim
