Working on a friends 88 park avenue and have a question about brake lines. The right front caliper had been dragging and wore the brakes out. They were hot enough to melt the plastic cap off the end of the valve stem (HOT!!). Well, I replaced both rotors and both calipers and a new set of pads of course. But, when it came to bleed the brakes (replacing fluid), I was unable to get any fluid to flow from the front right with 15psi and my Motive power bleeder. This was without the line connected to the caliper. Was able to bleed the new fluid thru by pumping the brake pedal though. The fluid that came out looked like liquid rust. Drivers side bled very easily with just the power bleeder and 10psi.
Now, this got me thinking. Might there be some sort of line blockage causing the hard bleed from the right front. Could it have been what caused the caliper to bind in the first place? Should I try just replacing the rubber line, or... ? I hate to burn up another set of pads and rotor if this one sticks as well due the line blockage or something like that. Or should I not worry about it as long as it drives ok?
Thanks for your thoughts.
-Deon
-Deon
