I had the injector pump rebuilt 30k ago. Pulled the fuel cone to see if the pin was moving, as a routine kind of inspection. The pin will only come out about 3/32 of an inch. I squirted in my favorite lubricant and worked the pin to no avail. It moves easily... . only 3/32 of an inch. Before the pump rebuild, I had checked it and it worked well... . slide out to the other side of the bore.
What moves the pin under normal operation... . fuel pressure? I also had diesel in the fuel cone bore. So I guess the seal is bad also.
Dave
Dave
