Does 'complete' include the 8 trailing arm bushings? They may 'seem' OK, but after 100k miles, they really are worn out. My truck wandered all over even though I'd installed the SSI sttering stabilizer and replaced the steering gear (which required me to relearn how to steer the truck). When I had the 8 bushings replaced, I again had to relearnt o steer the truck.
And, as Trat said, the steering gear could be loose; the sector shaft bearings could be worn, or the gear-to-frame mount could be dicey.
The steering shaft slip joint could also be worn and loose.
Other less likely causes? Tires with soft sidewalls can contribute. (I need new tires and have few funds available. I'll likely buy Wrangler HTs from Sams Club because they're cheap and have the stiffest sidewalls of all the tires they carry. [My stock wheels are way out of true after 315k miles; it ain't worth spending any more.] I'd love to put Yokohama TY303s on again; the truck drove like a sports car. Alas, I'd need new 19.5" wheels and I just don't have the money.) Another remote possibility is the rear suspension bushings. If they're really bad, they can cause steering issues.
