Stuck steering wheel radio control??
Exhaust Brake 06 pac in line or elbow...
6 trips to dealer, another to a mechanic and 2k later, it was just this
Was driving along today and flipping through radio stations using the steering wheel controls and the left side control all of a sudden got stuck. It still works but now if you barely slide your finger over it, it will change stations. Its the center button that is stuck, the one that changes the preset stations. Anyone ever experience this? It seems as if the spring or what ever is inside of the button is stuck? I have not had time to play around with it yet, I figured I'd try tdr before I try the screwdriver method.
I ended up taking the controller out and replacing it. The little raised piece in the middle got wore out and cracked which was causing the problem.
