Studded tires on my 2wd
timing and ksb
Turbo from 3rd gen
Put on my new Cooper Discoverer M&S studded tires saturday and got to try them out this morning on snowy, icy very cold roads this morning...
Awsum!
Coupled with the 6 cement blocks I have in the bed I was in control even on the steep hill I have to get up just before the place I work. I still have room for 4 more blocks so I think I'll top off for a little extra weight. Helps the truck ride better anyway.
Now when the roads dry out I'll have to try some sparky burnouts!! :-laf
Jay
Connecticut still allows studs, eh? No problem here, of course.
Why don't you leave the cement blocks at home and put a bunch of bags of sand in the bed? Double-bagged, of course, and held in place by something or other. Throw in a maxi-scoop or mini-shovel.
Then, if the studs won't hack the hill, you've got instant traction available.
Regards and best wishes for a fine holiday season in Torrington. DBF/Owen
HTML:
Thanks Owen. Same to you .
HTML:
Yes Nov 15 thru April 15
I like the cement blocks because they are clean, leave no mess (can't break bags like the sand) , and are easy to remove/reinstall when I need the space.
And I built a simple frame to keep them secure between the wheel wells.
Jay,
I filled two old tires with concrete. Used 3 bags on each (240 lbs. ) and have a lifting padeye that I can lift in and out with my bucket loader. However, this last trip, I picked up a load of wood on the first morning and it held me down pretty good. We didn't get as much as you all, but when you're taking a curve on an icy road in the swamps of southeast Virginia, can't be too careful.
EDIT- Oh yeah, I run Uniroyal Laredo AWT on the drives, and Laredo AWP on the steers. The only off roading I do is purely unintentional, so the more "grippier" tires on the rear.
My brother is a volunteer fireman and has seen some blocks go through the cab in some head on accidents. I try to think about what I carry and how to secure it more this time of year. Which reminds me I have to get some stuff out of my own bed today.
Thanks
PS Naturally I missed the part about the frame to keep them secure the first time, sorry
You don't need cement blocks... ... ... ... you can use my containers of vegetable oil and a few 5 gallon containers of B100... ... . I left them out the other night... . ugh!!!!!!!!!!
HTML:
No problem... . the reason they're secured is I've read about "projectiles" in the past... also I've seen pails of joint compound and sand wind up in some hairy spots after accidents.
I guess everybody has their own idea what to use for traction weight. . Tugboat's idea is unique, but the only lift mechanism I have at my disposal is my Armstrong lift... . so I might have to switch from cement blocks to bricks next year. . :-laf
Jay
