PToombs
I didn't think it was running right,my boost #'s were never as high as every body elses. When I put my 16cm housing on it cut the smoke quite a bit,and boost at 70 mph went from 1 or 2 to about 3 or 4. Well I hooked up the trailer and put the small tractor on and went to get a set of plows, taking the same route I take to work. At 60 mph, about 10 psi and egt at 1250* WOW! Houston we got a problem! At 70 mph 12. 5 psi and the same egt, but it didn't go any higher, thank goodness it rained, egt came down 100*. Tonite I pressure tested the intercooler,set the regulator at 20psi,hooked it up,no pressure on guage. Removed the POS and it looks like it got termites. I love living in the "salt city". Where can I get a better or bigger IC for a reasonable price? Any help would be appreciated. Thanks guys.
