dpuckett said:You'd be better turning the fuel screw in. In my experience, yuo can turn that "smoke screw" all you want and it has little to no effect. You can also loosen the AFC starwheel and put the tapered pin to the rich setting.
Daniel
tugboatphil said:Fuel screw on the aft side of the pump, almost to the block. 13mm lock nut and 6mm to adjust. If you have power on while adjusting, you can get a little spark off the shut off solenoid, if you hit it with the wrench. (of course, no one would be stupid enough to do that... .)
