The Surge!
My truck had the voltage flucuation also. Makes the engine hunt at an idle. There is a fix.
You need to install a relay. Instead of the key switch sending power to the regulator you have the relay send power to the regulator. The key switch will activate the relay. Use 14G wire for a good conductivity. If you need a schematic I can draw one up and email it to you. Also make sure you have really good grounds. I have the engine grounded to the frame in two places. The I have the body grounded to the frame. Also run a ground wire to one of the mounting screws on the regulator.
See if this helps
Key switch to activate relay
Ground on relay
Fused Battery signal (take right from battery post if possible
send fused battery voltage via realy to regualtor.
Malcolm
See if this helps
Ground on relay
Malcolm
