A bit, I'm working out bugs.
I got the O/D and lock up wired and ready to roll. I put back on my fan with the spacer, and I bought a radiator from Summit. I actually bought the same one you did and I used the extra space to mount my vegetable oil filter. I also installed a transmission cooler. Tommorow I am planning on working on my kickdown cable, 4x4 connecting rod, powersteering problem, and just getting the bugs out. I also need to get my transmission wired so the reverse lights come on, also it will start in gear currently and that could be dangerous. I'm also going to take a second look at my transmission mount and see if I can fab it to drop and 1/4 inch or so, and get it tightened down good. I don't want another radiator repeat so I'm carefully gong through because I want to be able to romp on it with letting my fan a radiator kiss. It seems like my motor is really flexing when I put it in reverse and forward. It leans to the front right corner in drive and back the opposite way in reverse. My buddy has an 03 and I opened his hood to seee how far his motor travelled and it wasn't much. For those that have first gen motors or conversions, How much play should I be seeing? Could my frame be twisting under torque?
