I plan to change my trans fluid and filter in my 48RE in the near future. Not wanting to spill fluid all over the garage floor, I'm searching and brainstorming different ways it can be done. I'm just curious, has anyone tried to remove the trans fluid that is in the pan by just sucking/pumping it out through the dip stick tube prior to removing the pan? If it can be done, it would save making a mess when you loosening the pan screws and also there is no need to drill a hole and then install a drain pan plug in the pan to save future messes.
