About a week and a half ago, my truck lost a significant amount of power. The first few times I noticed it, the truck seemed normal for the first few miles, then lost power. After a day or so, the power loss turned constant, always there.
My first thought was a leaky turbo hose, but I don't think this could be the problem, as the low power occurs under all conditions, including starting from a stop (i. e. low/no boost). This truck has never seemed like it had as much power from a stop as similar ones I test drove before I bought it (in late July), and you have to slip it a little more clutch now. I think the idle is a bit low as well, and it has never started without resting your foot on the accelerater.
My next thought was a plugged fuel filter, but I'm not sure how this would cause such a sudden power loss, and I don't think its hurting my milage like when the filter would get plugged on my 6. 2.
I haven't had a chance to thouroghly investigate the problem yet (its mid-term time), but I did check the intake tract to make sure I didn't suck up the cat (darn), and the filter didn't look too bad. I tried to wiggle the exhaust apart to see if it was plugged, but it wouldn't cooperated and I had to be somewhere.
The truck is bone stock with the exception of 255/85R16's, has 80,000 miles, and I adjusted the valves when I bought it (around 3000 miles ago). I plan on changing the fuel filter and checking the strainer in the next couple days.
Any advice would be greatly appreciated.
Pete
'97 2500 CC 4X4 5spd Sport
'83 K5 Blazer 350 TBI (ex 6. 2), 39. 5 TSLs, 3" lift, Dana 60/GM 14 blt, Detroits
Pete
