if it is a 1994-1998, it is most likely the fuel return line up under the intake manifold, back down to the firewall. I am replacing that line on a friend's truck, probably this weekend. I have found that 8mm transmission line works awesome. I use the kind used on a Nissan forklift. I have had to do this fix on several 12 valve engines and on a friend's 8. 3
Problem is the line cracks and allows air to enter. When the engine is off, it siphons the fuel out of the line and back through the fuel filter. To test, push the primer button about a dozen times and see if it cranks easier.
