Its the overdrive direct clutches that do not do anything when the transmission is in od. It is the od housing that holds 2 sets of clutches in it.
The od direct clutches are engaged to help out the one way clutch. They are primarily used in 1st gear , 2nd gear , 3rd gear , and reverse that is when they are engaged. It is the only set of clutches that are spring applied and hydraulically released.
Holding capacity of these clutches is determined by the strength of the spring. Steve since you have a 1995 truck in our own personal shop whenever they are available to us we use brand new od units . That spring in your particular case will have to be changed no matter which vendor you choose, we know transgo sells one but we prefer the oem one.
As for towing out of lock up you must monitor your transmission temps in the cooler lines. We do have a special towing TC that is designed to be used for extended fluid coupling . You would have to talk to my dad on how that works . Remember though as you have a 1995 truck and you want to tow for extended periods in fluid coupling you have to match your engine for what you intend to do. The transmission wont be your issue it will be your engine.
We have this down to a fine science as we do this day in and day out with the help of Piers from PDR and Lawrence at Diesel Dynamics.
