I am back to my Super-B turbo. I was setting everything back up and have it set as follows. #10 plate is now full forward, AFC is full forward, but star wheel is backed off a bit. The turbo is running at 45 psi max at full throttle. EGTS run about 1200, but I can get them to 1400 if I let the RPM get to 32-3300. I have not seen higher EGTs than that. The exhaust is hazy but not to bad. I might back the plate off a little if it gets out of hand. My main concern is head gasket. I have had the engine rebuilt but they did not o-ring or stud anything. Another issue is timing. I think my timing may be a little high but the truck seems to run fine. What sort of timing would be the best to run. I think the timing is up around 20* but i am not sure. The engine makes a little more noise than a stock engine does but its not bad.
