Originally posted by jerryrigg
Anyone know if people using the fingertouch plug has had any problems. Something I noticed it the factory plugs and superplugs have a machined area just below the gasket instead of threads all the way to the gasket like the fingertouch plug. I thinking we may be running out of threads and the plug is only hanging on by a couple threads...
any thoughts?
-Matt
I have used the "fingertouch" plug for a long time with PERFECT results in my Nissan Maxima. It's actually made by Fumoto Engineering, and it is a quality product. There's no comparison for convenience.
It usually runs about $25, and here's what I like:
- Never have to take a plug off or fish it out of oil
- it doesn't leak-- EVER
- The valve LOCKS IN PLACE, so it would take a VERY special kinds of bump to accidentally open it.
One POSSIBLE gripe is that the drain goes up high enough into the pan where it MIGHT not be flush with the inside floor of the pan. Thus, any particle and stuff that accumulated in the bottom would not drain out. I disproved this to my satisfaction, though, by taking the valve out and feeling the inside of the pan through the hole-- nothing.
The other possible gripe is a slight reduction in ground clearance at the oil drain. If you drive where you might dent your oil pan, you also might shear the valve off and then you would REALLY be hurting. For me, this is not an issue, since the ground clearance is plenty, and I feel this is a remote risk and not likely.
The valve is machined from a solid chunk of brass, and has a stainless steel ball valve in it, with nylon bushings for sealing.
I highly recommend it; I feel it is a very high quality product. They've been selling them for over 25 years, and millions of plugs later, no recalls. You might want the version without the nipple, as it's lower profile (it sticks out about 3/4 inch)
JMO
HOHN
