Superlift suspensions
Steel Wheel's 19.5"
2 gen badges on a 3 gen?
6" lift here. I like it. Rides nice. Way better then stock. I did blocks in the back to keep the tow ratings. After 50,000+ miles my shocks are starting to take a beating. I've had custom sway bar links made because I bent the ones that come with the kit while off roading. Been through 1 pitnam arm joint. Need another now. Front end is starting to sag a bit, maybe 1/2". Overall 7 out of 10.
driver, what size tires are you running? I was looking into a Lorenz kit, but I just got back fron thr Indy jamboree and now I want to run a bigger tire. I was thinking about a 37x13. 5x22
I've got the 6 inch kit running 37x14. 50R18 Kumho KL78s. I think they make set for 22s I highly reccomend this tire they run really smooth, grip nice offroad, have a high load rating (3400lbs) and not to mention cheap (193 a tire at tirerack.com) The kit runs real nice but I would get the bilsteins the superlift shocks were a bit stiff for my tastes. Either way she runs awesome very little body roll around a turn flexs real nice off road too.
35X12. 5X17
I didn't want to go bigger. I drive/tow a bunch in the middle of nowhere and with a blow out I can still put my spare on to get me where I need to be. Look in my gallery. I think it looks fine. Some people don't like it. I personally don't like the lift with 37". Just me. We all have our own tastes.
I will say this having driven with both 35s and 37s on the lift if you have the 3. 73 gear I don't suggest getting the 37s I have em and I'll tell you with the 35s I could do 80 with my 4000# boat 6th gear no problems nice and cool. With the 37s I tried to do 80 and it was 800 degrees post turbo foot nearly on the floor. The other issue is I used to get 20-24 at 55mph empty on the 35s now the best I can manage is 17-18 at 55mph so take that for what it's worth personnally I'm gonna go to a 36 or 35 on the next set of tires. So I would think hard about the size but as i said before I do reccomend the kumho kl78
Thanks for the imput, Driver I like the look of your truck after looking at your pics the biggest I would go on a 6 inch ligt is 36's. thanks you guys have been a lot of help
I have the 6" Superlift and a 3" body lift. I'm running 38" toyos on a 10" wide rim. No rubbing at all, rides better than stock.
kore just came out with their new technical series which is a full 5. 5 inches and is all spring, has alot of travel, clears 37's and has all the good fox shocks. You can see it on one of Bank's trucks.
Mileage is not a concern with me. According to my overhead display, it is 17. 1 mpg. If it is accurate or not, I really don't care-at least it looks good!
What is a lot of travel equate to on a measuring tape?
Bob
KVoigt said:
big easy thats caculated mileage but the truck only has 2000 miles on it
Ok, but has your speedo been corrected since you put the bigger tires on? That will affect mileage in a BAD way, since it will show that you've gone less miles than you really have...
