Seafish, how where the Spicers to install?
I have heard a lot of issues with them not fitting and needing to be ground, and that's on the "application specific" ones. Several of my local shops had so many issues they quit carrying them and only use the OEM AAM joints.
All that being said, my understanding now is that at a more recent point in time, Spicer DID choose to make and market application specific ujoints for the Dodge/AAM axles.
Do you know if that is also true for the rear drivehaft? Jusy about ready to buy the 4140 conversion for one truck becausee cannot get rid of the vibrations in the rear driveshaft. I suspect the ears on the yoke have been bent as you saw happen and it is now out of line.
So I do remember that there were in fact SPicer/AAM fitment issues early on between Spicer and the AAM axles that Dodge uses...apparently there was NO application specific Spicer/Dodge fitment available and the ones that were closest to fitting, STILL needed to have either the clip or the ear filed down by a few thousands. This was further complicated by Dodge using various front drive shaft parts that had different diameter knuckles, each permeation of which needed a diffferent ujoint. All that being said, my understanding now is that at a more recent point in time, Spicer DID choose to make and market application specific ujoints for the Dodge/AAM axles. I can attest to the fact that the ONLY problem I had with installing them were casued by me (lol) 1) I dropped one needle bearing in a cap while doing the cardan joint rebuild and 2) bending the ears on the front axle shafts knuckles slightly in when using a hydraulic press to push out the old ujoints...did NOT realize that I had bent them until not being able to get he clip in on the cap despite being fully seated...I actually thought that the SPicer/AAM fiutment issue had come to ahunt me, despite George's assurances, but then I took measurements and realized what happened!!! (lol)
In any case if you want an even clearer understanding, I do advise you to call George at 8Lug...I am sure that he would readily answer any specific questions you might still have.
So far, my truck is driving GREAT with the work I did (including the BD sway bar end links that I remember you were sceptical about!! (lol)
I recall, it's been a year, that the local driveshaft shop was still having issues with the application specific ones. But for sure I know I went with AAM's at their recommendation.
Did you go with sealed or greaseable Spicers?
My only OE ujoints are the front driveshaft. The rear driveshaft was replaced with a 1 piece alum this spring, and has 1550 ujoints.
Have you noticed any significant blockage of air to the intercooler? Since I ordered my bumper unpainted I was thinking of adding a duct or perhaps two to direct air where it needs to be.
The only joints I really looked at where the axle joints. I don't recall part numbers, but the 5006813 looks familiar. If it's their sealed ujoint for the axle joints then I would say it's the one with issues.
However, unlike my stock bumper (going off recollection here) the Buckstop bumper has two openings on each side of the winch that measure 2 1/2" x 8" that allow air to the lower portion of the coolers.
After thinking about your question I popped my hood and took a look at the bumper and the cooling systems in the front grill area. The bumper covers the lower 1/3 of the coolers. However, unlike my stock bumper (going off recollection here) the Buckstop bumper has two openings on each side of the winch that measure 2 1/2" x 8" that allow air to the lower portion of the coolers. Rather than blockage it seems the Buckstop bumper will actually improve air flow.
I took some photos but can't figure how to attach them!
