OK 1st Genners I can usually trouble shoot pretty good but this ones eluding me. For a while I was getting a good vibe when making a turn. So far I have replaced both front wheel bearings, upper king pin bushings, tie rod ends, drag link, steering box and upgraded the steering shaft to a borgensen. I've also replaced the rear diff fluid and added modifier just in case it was a rear diff chatter mistaken for a front end vibe. The vibe has been significantly reduced but is still there.
Now on top of this when I hit a bump or curb in such a way that the truck rolls from side to side quickly I'm getting a lot of clanking noise from the front suspension. I'm also feeling the road more through the floor than I used too. If I try and rock the truck on the ground I cannot recreate the clunks. I've hung the front end but cannot find anything loose. Spring bushings feel tight though I'm sure they've seen better days. Now today on the highway the truck would slowly wobble side to side. Kind of like the tires were following a wiggly line. It is not constant or to a great degree but enough to get my attention.
Jay
Jay
