I have a 1999 Dodge 1 ton 4x4 Diesel Auto that I am swapping a motor in. I have a brand new motor that has the ecm and harness on it, it was a 02 with a stick. The 02 does not have a crank shaft postition sensor toner ring on the crank. Will the ecm off of the 02 work in place of the 99. . I have started the truck with the 99 ecm and it will run but throws a CSP code. . Does anyone know what I should do... Oo.
