yeah, a 6sp w/ 3. 42's front/rear would be a pretty sweet rig!
Roofer Dave, at 1800 RPM, that gives me 65 MPH with 3. 73 gears. 3. 42 gears are 8. 3% shorter, so at 65 MPH, I should slow the engine to 1650 RPM, the same revs I see at 60 MPH, where I get 2 MPG better mileage. I will in no way be lugging the engine at 1650, so I honestly expect to see most of that 2 MPG gain. I would be happy with that, even a bit less.
With your reasoning, I could travel 150MPH at 1,650RPM and get the same mpg.
Wind resistance, and the power required to push your truck through the air is a bigger factor than RPM.
Lowering your truck, running lower profile tires, and smoothing out the undercarriage, along with running a camper that slopes from the cab, to the tailgate would make a bigger difference.
Merrick
Well Dave, just because I wouldn't do it, doesn't mean I should bring you down now does it. Good luck, and let us know.
The ECM/PCM does not have to be reprogrammed for gear changes. The speed sensor is in the differential and only measures axle speed, so changing transmissions, or going to 2low or 4hi, or going from 3. 23's to 5. 11's won't effect your speedo, but changing tires would.
Merrick
I just know that when I slow down, I get dramatically better fuel economy and it all can't be attributed to wind resistance.
