Joe, I have a thermocouple in my intake, believe Dawson does also. My main experimenting has been tiring to get the intake temp HIGHER in cold weather. Ideal intake temp is 50-90°F. Found that a Physcotty really makes for cold air, stock airbox with a winter front was good for about 10 more degrees F than no winter front. Winter front with the airbox snorkel removed and fender hole blocked raised the temp 30° more. Winter front with fan removed, fender hole blocked was the best, 55° higher than just the plain stock setup with no front. The stock setup @ 0° ambient only had a intake temp of 20-35° depending on boost, much too low for good engine efficiency.
As far as high temps I've never tried blocking off the fender hole in the summer but think it would raise the intake temp more than it does in the winter. Will have to try that one. Have found that with a front on or fanless not moving above 70° that the intake temp skyrockets up to 140°+. Running the AC also jacks the intake temp way up, I think it's due to the hot condenser air flowing though the intercooler.
