Swepco Gear Oil
Anatomy of a Frantz toilet paper bypass oil filter
Fleetguard HF6604 Rant
Has anyone used this prod. Pro/con was looking for a little heavier weight instead of 75/90 the summer long runs and higher weight's of trailer pulling have to be hard on 75/90 SWEPCO High Quality Gear Lubricants The 210 or the 212 was what I was looking at
Using a gear lube such as you are looking at, will actually make the diferentials run hoter!
Here is a good article on gear lubes. https://www.amsoil.com/lit/g2457.pdf
Read it through, then make an informed decision.
