Switched grid heater modules
tag light lenses
first gen on the home page
Thanks to Alan- Paychk for all the technical info over the years. He's mentioned the grid heater module on the firewall driverside is what controls the grid heaters... at least on early non-intercooled trucks. Mine being an early 89, my grids don't preheat til 15*F as apposed to I believe 50*F for later grid heater modules/trucks. 15*F is fine if you don't have a bunch of fuel putting out your fire on startup early mornings and don't have a bunch of timing. Three previous winters I never had a problem with starting at temps just above 15*, which the grids would not preheat. Temps say between 18* to 30* the truck would fire instantly but not want to keep running. After a second try it may catch and hold on, but rump/romp romp, idle rough for a few seconds. If its cold enough to preheat, I'd get an instant start, sweet idle/ no white smoke almost like its 50* out.
So since I've had various parts from a 90 model Dodge Cummins laying around, I finally swapped out grid heat modules. Temp was 33*f out, normally I'd never see 'wait to start' - preheat at that temp, but after switching them out, I seen the WTS light come on as it should below 50*.
I'm not sure what the part number cut off is for early modules off hand, its in the search feature and in one of my Cummins manuals. The pn on the 89 module was something like 30,xxx. The 90 module was something like 110,xxx. The part number is found on the rear/firewall side of the module.
Hello and thanks for bringing that to my attention! I will have to check mine out and see, been plugging it in or had it parked using a different FWD truck with the snow here. It is a balmy 31 degrees here tonight and has been reasonably bearable for several days now, but we were experiencing single digits abnormally early this year. Not to complain too much, I am used to it by now. Oo.
Bill,
In a nutshell, your saying that your swapped out the contol module (black box) on firewall and you have preheat at a warmer temp?
My 90 seems to come on at about 40ish give or take.
-S
Greenleaf said:
Bill,
Yes sir, preheat now at a warmer temp.
