The guy who I bought the truck from was the original owner. He provided me with all the records, and I put them on an Excel spreadsheet. At the time I traded the truck it was in need of more front end work.
Maintenance and Repair Records -- 2004 Dodge Pickup Ram 3500
Oil Changes
Date Miles Interval Description
9/29/2003 6 Original Purchase
12/30/2003 3,234 3,228 Oil Change Delvac
3/5/2004 6,935 3,701 Oil Change Delvac
5/30/2004 23,097 16,162 Oil Change Delvac
10/14/2005 39,258 16,162 Oil Change Delvac
1/5/2006 43,277 4,019 Oil Change Delvac
2/14/2006 45,039 1,762 Oil Change Delvac
6/28/2006 55,329 10,290 Oil Change Delvac
8/23/2006 59,648 4,319 Oil Change Delvac
12/8/2006 66,261 6,613 Oil Change Delvac
4/24/2007 74,672 8,411 Oil Change Delvac
6/1/2007 77,296 2,624 Oil Change Delvac
7/20/2007 80,570 3,274 Oil Change Delvac
8/31/2007 84,229 3,659 Oil Change Delvac
12/18/2007 91,180 6,951 Oil Change Delvac
3/27/2009 98,606 Purchased by Hardrocker
3/29/2009 98,721 7,541 Oil Change Shell Rotella T, K&N Filter
8/31/2009 105,095 6,374 Oil Change Shell Rotella T, K&N Filter
11/21/2009 107,543 2,448 Oil Change Shell Rotella T, K&N Filter
5/11/2010 112,060 4,517 Oil Change Shell Rotella T, Cummins Filter
8/23/2010 121,883 9,823 Oil Change Shell Rotella T, Baldwin Filter
Other Maintenance and Repairs
6/4/2004 55275539-AE Backlite 23064314(?)
2/14/2006 45,039 Tires, Auto Trans Flush, Fuel Filter, Oil Chg.
8/23/2006 59,648 Replace Fuel Filter
12/8/2006 66,261 Replace Air Filter
4/27/2007 74,672 Tire Rotation
7/20/2007 80,570 Replace Air Filter, Transmission Flush
7/30/2007 Front Brake Pads and Rotors
11/1/2007 Joint Non
11/1/2007 AB Joint Non
12/18/2007 91,180 Fuel Filter
2/1/2008 92,718 Warranty Work -- Replace Fuel Transfer Pump
2/6/2008 92,718 Warranty Work -- New Lift Pump
2/6/2008 92,718 Replace Fuel Filter
2/14/2008 Ball Joints, Rotors, Pads, Hubs, Shoes, Tie Rods, Damper
3/1/2008 AB Joint Non
3/12/2008 AB Joint Non
4/2/2008 Pad Kit, Shoe Kit Drum
2/6/2009 Sensor Ant
3/27/2009 98,606 Vehicle Purchased by Hardrocker
5/6/2010 111,976 19,258 Replace Fuel Filter -- Supplied in Jeno's kit
7/24/2010 114,181 33,611 Flush and Refill Transmission
7/26/2010 114,941 Replace Drag Link and Pittman Arm
8/25/2010 121,913 Drain and Refill Differentials
8/25/2010 121,913 Replace Air Cleaner
9/24/2010 122,517 Traded on Ford F350
