Switches replace stock cup holder?
Need Help Choosing Bilstein Shocks
Hummer Wheels
Originally posted by Amianthus
Shelby,
Those radios/siren are being held up by two 1. 5" wide strips of Aluminum that I bent and fastened to the front frame and the back frame of the dash. If you pull out the cubby, you'll see what I mean. If one were to use steel, it would be really rigid. Right now my radios move a little bit, but that's because of the Aluminum. I have access to alot of it here at work. I then attached my top braket to the ones in the dash and made two more aluminum supports and screwed them into the sides of the remaining equipment. They aren't going anywhere. If you are gonna do something like this, check to make sure your shift pattern keeps clear of the equipment. Also, make sure that you don't bump your "Super Buddy" mug into the siren while the lady in front of you is trying to place an order in the drive through. :D
Truckie, If you have a 6sp or a short-throw 5sp, this setup will work really slick. Other than that, it's a pretty straightforward install. Just pull out the Cubby and use your imagination.
Great Pictures
These are great looking installations I have a o3 and looking put a FM and CB in somewhere. Did i see a HAM outfit in there somewhere????Radar Doctor
Shhhhh!!!!! Not so loud.
Yeah mine's a HAM outfit. 10,11,12 meter. However, because I don't have a License yet, I have cut it off to only use CB (frequencies in the 11 M). I want to get one, but two things are stopping me. Time and resources (local HAM club isn't really very active). Not to mention in order to use all the frequencies the radio is capable of, I need a technician's license of the highest magnitude. So for now, it just sits there picking up truckers as I cruise down the highway. And that works just fine for me. For now.
