Is your eng. turning over slow or what, can you plug in? I'm running rotilla 15-40 , I would warn against using a oil that thin unless there is no other opp. less lubrication with thinner oils, if no symtoms that are related to oil , turns over slow and not bad batteries , connections !!! leave in, I never heard of
any eng. oil that is not compatible with others , especaly if doing a change.
I do like how you set up your truck.
