Switching types of oil
Question about timing tools
Eliminator pipe noise ?
Got my email update of an Industrial Lubrication Journal that I supscribe too, today. I thought that this might help allot of people understand what happens when switching from a regular oil to synthetic or back. It is rather interesting and is something that should be thought about when switching from one type of oil to another. ;) I run synthetic.
"I am considering replacing the mineral oil in my engine with a synthetic oil. The engine has 50,000 miles on it. I have heard that the mineral oil and synthetic oil are compatible. Is this true?"
Generally, the reference to synthetic oil for an engine, means a lubricant is formulated with a polyalphaolefin (PAO) base oil. PAO, which is often called synthesized hydrocarbon, is pure and is compatible with mineral base oils.
However, because the PAO base oil does not dissolve additives effectively, it is usually formulated with an ester co-base (usually di-ester and/or polyol ester). The additives are soluble with the ester and the ester is soluble with the PAO.
Likewise, the PAO tends to cause seal shrinkage and the ester causes seal swelling, so the effects are offset when both base oils are present. It is the ester that can cause problems when one changes from mineral to synthetic.
Ester base oil used alongside PAO base oil in lubricant formulation has excellent natural detergency. In other words, it will clean up varnish on component surfaces as a result of thermal and oxidative degradation of the lubricant. When one switches from a typical mineral-based engine oil to a typical synthetic-based oil, the varnish layer will be removed by the ester in the synthetic oil and become suspended.
This suspended material can rapidly clog filters and can block oil flow passageways and lead to component starvation. The same is true for gearboxes and other industrial machines.
So think twice about switching to synthetic oils in applications where the engine or other machine has been operating for some time with mineral oils. If you decide to make the switch, try to clean the system before making the change, then monitor it carefully once you start it up.
Drew Troyer, Noria Corporation
synthetic oil
:D for your truck at 50k you will be fine to go synthetic most modern diesels dont carbon up inside like the gassers do unless you dont change mineral oil often (3-7k) then it will start to build up with soot and wear metals then the oil gets thick from viscosity shear or thin due to fuel dilution. filters are a big concern as well. what i would do is i would run amsoil 15-40 and every thing should be fine, if you wanted to amsoil offers a engine flush that i have had good luck with.
I completely agree with this. I f worried about the varnish the amsoil flush will take care of it.
My truck has been on Amsoil 15/W40 since 1500 miles. I now have 160,000+ on it. I just posted what I found to help those not familiar with the subject to have a better understanding about what happens when switching up oil types. :)
The Amsoil engine flush and flush procedure are really a necessity before switching to a synthetic. PN#: AEFCN, about $5. 00 for a 16 ounce bottle. You'll need 2 new clean oil filters too... . Prefferably the Donalsons..... Good insurance before starting off on the synthetic trail... .
amsoil
yes and no to your questions yes, at your mileage i would consider the amsoil flush but you dont have to, i say this because it makes no sense to put clean oil in a dirty engine,the flush does not break apart the carbon in side your, instead it will liquifycarbon in you engine in 10-15 min. Amsoil is formulated to clean as it protects---like no other oil, so you will never get carbon build up, even with drains longer than 100k! i've seen it. and no to you other question because it liquifies the carbon and doesent break it apart. i would just pour it in as is and let it run for 15 min at idle. or if you feel better the other way would work to.
