Ereynolds72 said:
Along the same lines as this discussion, did any of you read the article in a recent TDR issue about the guy who ran 125,000 + on his Amsoil Oil? He used a bypass filtration system and sample analysis. I don't have it in front of me but I'm thinking it was closer to 153,000 miles on the oil.
In addition, is there a specific method to be followed to convert to a full synthetic or do you just swap at the next oil change?
Do dealerships test the samples or do you have to go to a diesel shop. Where can you go to get you samples analysed?
The longest I have gone on a "single" oil drain, was 105,000 miles over a 5 year period of time, and the oil at that time was still in "suitable for continued use", as per the oil analysis at the time. I did change the oil, simply because I wanted to try the Amsoil 5W-30 Heavy Duty Diesel oil.
I use oil analysis on a continuing basis at 10,000 mile intervals, and I have the Amsoil by-pass oil filtration system as well. My current truck, an 03' 4X4 Quad Cab, now has 37,000 plus miles, over a 2 year period of time. The 15W-40 Amsoil Diesel/Marine oil was installed at 8,500 miles and is still in the engine at this time. I have had 2 oil analysis, and is now due for the third analysis.
There is nothing special you have to do to convert from a petrolium oil to synthetic oil, unless you have a lot of miles on your egine... ... ... ... ... ..... just dump the current oil, and put the synthetic in.
If you are going to extend your oil drain longer than a year/10,000 miles, then I would suggest haveing the oil analysed. (It is a very simple process) I use Oil Analyzers Inc. and get the kits from Amsoil Inc.
Hope this helps,
Wayne
amsoilman
