Synthetic vs non synthetic?
Search will give you lots of good and so-so info. Might be worth covering again without getting into brand preferences.
Been in oil business for 20 yrs-here is what I have learned.
Two ways to skin this cat!
1- Use good non synthetic and chang at 5,000 miles. If heavy towing-around 3,500 miles.
2-Use good synthetic (some are better than others) and get 10,000 miles (light towing) and 7,500 miles (heavy towing).
These milages as generalizations and need to be adjusted for personal conditions.
Lots of misconceptions about synthetics! Fact is- only 2 advantages to using them.
1-Thermal Stability-If your oil gets hot, over 200 degrees, for any lenght of time, synthetics will protect better and NOT cause gum, varnish, carbon to sludge up your engine. and they will return to more usable condition after being worked hard.
2-Because of #1, and the fact that synthetic oil is a cleaner molecule, it lasts longer - Ball park = twice as long. At todays prices synthetics are fairly cost effective due this fact.
Note: Good filters do not need to be changed more often
than oil if above change intervals are used.
Note: Changing oil & filter often is cheapest insurance we have against poor running, hard starting, high maintenance engines at 100,00 or 200,000 miles.
Note: Good fuel conditioner will give same benefits down the road by keeping upper half of engine clean!
