SYRYKER Install module.
3500 SRW Availability?
2011 3500 Exhaust Brake Operation Question
STRYKER Install module.
The Bank connections will require a Harness puller or Huge lock jaws. My spelling like usual Is bad If You have Question(s) call If I can answer them I will otherwise call TS, Tech support is good.
It is all Plug and play, takes Maybe 30 Minutes to install and remove in as little as 3 seconds (Ripping it out) or 15 minutes to remove by disconnecting.
I will see if I can post the instructions (No pictures that's why I posted them)
All My posts will be bias Now I'm buying in. It differently brings the power on in mid to WOT.
This truck also Has Rail and Pump mods, Most don't realize that all 6.7 Rails have internal restrictors. They do help for flow (one Direction but do restrict Volume in the process)
I will know more this weekend.
Looks like it's the new TS Stryker.
According to the literature it's a duration module, so without timing I wonder how hot it gets?
