Wasn’t $208 for just coolant. That was entire bill . Total bill probably was $280 ish . Reason I can’t give absolute numbers is my copy doesn’t have numbers. The copy I signed had The numbers only got to see it for a moment. Gal at counter said I get a copy so I quit reading the original. My best recollection was 2.5 gal coolant $ ? 1 hr labor neighborhood of just over $100 . The pump was $80 something.
Apparently there’s no clean way to drain coolant?
Lastly after cleaning up the antifreeze that was all over the underside of engine compartment it appears that things are ok , no leaks , hallelujah
The recall water pump is not $80,not that it matters.If the dealers that are charging 2.5 gallons of coolant on all the recalls get an audit they will be returning some $ to FCA.
