Is there any periodic maintenance neccessary for a T-case? Mine makes a lot of noise. It's nothing new, the noise that is. It seems to have gotten louder over time though. It's the normal noise that everyone attributes to the NV5600 but I've always though it's the T-case because if you move things slowly with the truck jacked up, it makes the same noise at the T-case, only slower. Anyways, is there any preventative maintenance such as bearing or whatever I should be thinking about?
The T-case on my '01 started popping out of 2HI at around 129K miles. Not a lot of fun having the truck try to jump out of it's shoes going down the freeway. That was most likely because I didn't change the fluid for the first 106K. I've learned that lesson.
